- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: ?? ?? <sophiee_shao AT hotmail.com>, Coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] (no subject)
- Date: Thu, 19 Apr 2007 12:25:18 +0200
Le Thu, 19 Apr 2007 10:34:55 +0100,
Edsko de Vries
a écrit :
> Did you compile XX? As far as I know, Require Import only opens
> compiled libraries. To compile XX, open it in coqide, then select
> Compile -> Compile Buffer. Then try the import again; it should work.
> Edsko
You should also make sure that the compiled file (.vo) is in the path.
You can do that at launch:
coqide -I <path> -I <path>
or inside coqide by the command
Add LoadPath "path".
By default the current path (the path where the current file is) is in
the path.
Cheers,
Pierre Courtieu
- [Coq-Club] (no subject), dz dz
- Re: [Coq-Club] (no subject),
Edsko de Vries
- Re: [Coq-Club] (no subject), Pierre Courtieu
Adam Chlipala
dz dz
dz dz
- <Possible follow-ups>
- Re: [Coq-Club] (no subject), dz dz
Edsko de Vries
