coq-club - Re: [Coq-Club] (no subject)
chronological Thread
I have compiled (.v) files successfully, after using "coqc.opt XX" command.
Thank you all!
Ying
Message: 1
Date: Thu, 19 Apr 2007 12:25:18 +0200
<pierre.courtieu AT cnam.fr>
To: Edsko de Vries
<devriese AT cs.tcd.ie>
Cc: ?? ??
<sophiee_shao AT hotmail.com>,
Coq-club AT pauillac.inria.fr
Subject: Re: [Coq-Club] (no subject)
Le Thu, 19 Apr 2007 10:34:55 +0100,
Edsko de Vries
 a ?crit :
> Did you compile XX? As far as I know, Require Import only opens
> compiled libraries. To compile XX, open it in coqide, then select
> Compile -> Compile Buffer. Then try the import again; it should work.
> Edsko
You should also make sure that the compiled file (.vo) is in the path.
You can do that at launch:
coqide -I <path> -I <path>
or inside coqide by the command
Add LoadPath "path".
By default the current path (the path where the current file is) is in
the path.
Cheers,
Pierre Courtieu
--__--__--
Message: 2
Date: Thu, 19 Apr 2007 09:13:22 -0700
<adamc AT cs.berkeley.edu>
To: =?GB2312?B?ZHogZHo=?=
CC:
dz dz wrote:
> when I input "Require Import XX" the coqide show that :User error:
> cannot find XX library in loadpath. Here XX means some coq file i
> wrote before, it not belongs to the coq libraries.
> Is it because I use coq under windows system? I tried put the file I
> want to import under different directories,the command didn't work.
"Require" loads compiled (.vo) files. You could compile your XX.v file
with the command line 'coqc XX' to produce XX.vo, and then the"Require"
should work if the .vo file is in the current directory. Otherwise, use
the "Load" command instead.
--__--__--
Message: 6
To:
Date: Fri, 20 Apr 2007 13:51:37 +0800
>From: Adam Chlipala
>To: dz dz
>CC:
>dz dz wrote:
> > when I input "Require Import XX" the coqide show that :User error:
> > cannot find XX library in loadpath. Here XX means some coq file i
> > wrote before, it not belongs to the coq libraries.
> > Is it because I use coq under windows system? I tried put the file I
> > want to import under different directories,the command didn't work.
I have tried to compile many (.v) files, but all the files can't be
transformed to (.vo) format.I manipulated step by step as follows: open XX
file-> select "compile"-> select "compile buffer". Then  coqide indicated
that : compilation output: 'coqc' ¿Ú ¿Ú ¿Ú ......(with many squares) .I
don't know what the problem is.
I always use "Load" instead of the "Require" command , is there any
difference between these two command?
Best Regards,
Ying
_________________________________________________________________
Ãâ·ÑÏÂÔØ MSN Explorer:   http://explorer.msn.com/lccn
--__--__--
Message: 7
Date: Fri, 20 Apr 2007 09:17:18 +0200
To: =?gb2312?Q?=C7=B3_=C7=B3?=
Cc:
Le Fri, 20 Apr 2007 13:51:37 +0800,
dz Ç³
 a ¨¦crit :
> open XX file-> select "compile"-> select "compile buffer". Then
> coqide indicated that : compilation output: 'coqc' ¿Ú ¿Ú
> ¿Ú ......(with many squares) .I don't know what the problem is.
You should compile files by hand on the command line to see the error
messages. Probably you have to change all your Load commands by "Require
Export".
coqc filename.v
you should have the "bin" directory of coq installation in your path.
Yes, Load actually reads and interpret the whole file, which is very
slow. Require (Export) loads the compiled file, which is much faster.
Moreover when using compiled files you can have several definitions
with the same name in different files without problem (use
"filename.name" to distinguish).
You definitely should compile your files. The best way is to do it on
command line with a makefile. You can use the coq_makefile tool which
is included with coq. It seems you are under windows so you should
probably install gnumake (http://www.steve.org.uk/Software/make/),
unless you are under cygwin. I never use coqc under windows. If you are
under linux, coq_makefile is what you need.
Best regards,
> Best Regards,
> Ying
--__--__--
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
End of Coq-club Digest
ÓëÁª»úµÄÅóÓѽøÐн»Á÷£¬ÇëʹÓà MSN Messenger: http://messenger.msn.com/cn
