coq-club - Re: [Coq-Club] (no subject)
chronological Thread
<adamc AT cs.berkeley.edu>
To: dz dz
<sophiee_shao AT hotmail.com>
CC:
Coq-club AT pauillac.inria.fr
Subject: Re: [Coq-Club] (no subject)
Date: Thu, 19 Apr 2007 09:13:22 -0700
dz dz wrote:
> when I input "Require Import XX" the coqide show that :User error:
> cannot find XX library in loadpath. Here XX means some coq file i
> wrote before, it not belongs to the coq libraries.
> Is it because I use coq under windows system? I tried put the file I
> want to import under different directories,the command didn't work.
"Require" loads compiled (.vo) files. You could compile your XX.v file
with the command line 'coqc XX' to produce XX.vo, and then the"Require"
should work if the .vo file is in the current directory. Otherwise, use
the "Load" command instead.
I have tried to compile many (.v) files, but all the files can't be transformed to (.vo) format.I manipulated step by step as follows: open XX file-> select "compile"-> select "compile buffer". Then coqide indicated that : compilation output: 'coqc' ¿Ú ¿Ú ¿Ú ......(with many squares) .I don't know what the problem is. I always use "Load" instead of the "Require" command , is there any difference between these two command?
Best Regards,
Ying
_________________________________________________________________
Ãâ·ÑÏÂÔØ MSN Explorer: http://explorer.msn.com/lccn
