- To: Marko Malikovi? <marko AT ffri.hr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] assumption after split
- Date: Mon, 7 May 2007 12:53:22 +0100
On Mon, May 07, 2007 at 01:47:16PM +0200, Marko Malikovi? wrote:
> Greetings for everybody,
> I'm new in Coq. Please, can somebody explain to me this error:
> Coq < Section Proba.
> Coq < Variable A B:Prop.
> A is assumed
> B is assumed
> Coq < Hypothesis H:A.
> H is assumed
> Coq < Goal A /\ B.
> 1 subgoal
> A : Prop
> B : Prop
> H : A
> A /\ B
> Unnamed_thm < split;assumption.
> Toplevel input, characters 6-16
> > split;assumption.
> User error: No such assumption
> Thank you very much,
After split, you need to prove A and B, but only A is an assumption (B is
not).
If you add another hypothesis H':B, it should work.
Edsko
- [Coq-Club] assumption after split, Marko Malikoviæ
- Re: [Coq-Club] assumption after split, Benjamin Werner
- Re: [Coq-Club] assumption after split, Edsko de Vries
- Re: [Coq-Club] assumption after split, Pierre Casteran
