coq-club - Re: [Coq-Club] assumption after split
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] assumption after split
  • Date: Mon, 07 May 2007 13:56:12 +0200
Hi.
Marko Malikoviæ a écrit :
Greetings for everybody,
I'm new in Coq. Please, can somebody explain to me this error:
Coq < Section Proba.
Coq < Variable A B:Prop.
A is assumed
B is assumed
Coq < Hypothesis H:A.
H is assumed
Coq < Goal A /\ B.
1 subgoal
  A : Prop
  B : Prop
  H : A
   A /\ B
Unnamed_thm < split;assumption.
Toplevel input, characters 6-16
The tactic "split" generates two subgoals, and the tactic "assumption" is applied to each of one (because of the
operator ";").
The first subgoal (proving A) is solved immediately. But the tactic "assumption" fails on the second one
(proving B) because you have not assumed B.
If you add the hypothesis H':B, your tactic works.
Notice that with "split; try assumption", the first subgoal is solved, and the second one remains unsolved.
Pierre
split;assumption.
User error: No such assumption
Thank you very much,
Marko Malikoviæ
Faculty of Arts and Sciences in Rijeka, Croatia
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
