coq-club - Re: [Coq-Club] Subset of natural numbers
chronological Thread
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Subset of natural numbers
  • Date: Wed, 5 Sep 2007 03:30:26 -0400 (EDT)
On Wed, 5 Sep 2007, Marko Malikovi? wrote:
Greetings,
I need to work with small subset of natural numbers, from 1 to 5.
Normally, I can define it in this way:
Inductive in_subset : nat -> Prop := in_subset_def : forall x : nat,
1<=x<=5 -> in_subset x.
But, for my needs is more appropriate to have definition like this:
| C1 : in_subset 1
| C2 : in_subset 2
| C3 : in_subset 3
| C4 : in_subset 4
| C5 : in_subset 5.
Is something theoretically (from view of Cic) wrong with this kind of
definitions?
There is nothing wrong with your second definition, (although personally, inductive families always bother me a bit). However I should point out that you can have the best of both worlds.
Your second definition produces the inductive principle:
forall P : nat -> Prop,
       P 1 -> P 2 -> P 3 -> P 4 -> P 5 -> forall n : nat, in_subset n -> P n.
You can write this theorem for your first definition without much difficulty.
Lemma in_subset_ind' : forall P : nat -> Prop,
Proof.
intros P P1 P2 P3 P4 P5 n H.
destruct H as [[|[|[|[|[|[|n]]]]]] [H0 H1]];
 solve [assumption|elimtype False; omega].
Qed.
Then this new inductive priciple can be used on demand using the
`` elim H using in_subset_ind' ''
(or `` induction H using in_subset_ind' '' if you had a truely inductive definition).
Goal forall n, in_subset n -> in_subset (6-n).
intros n H.
elim H using in_subset_ind';
simpl; repeat constructor.
Qed.
You can write your own pseduo-constructors.
Definition c1 : in_subset 1.
repeat constructor.
Qed.
Definition c2 : in_subset 2.
repeat constructor.
Qed.
The result is that you can use your old definition on almost all the same ways you would use your new definition.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
