coq-club - Re: [Coq-Club] symmetric equality
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: "Stefan O'Rear" <stefanor AT cox.net>, Ethan Aubin <ethan.aubin AT gmail.com>
  • Subject: Re: [Coq-Club] symmetric equality
  • Date: Sat, 29 Sep 2007 14:18:20 +0100
  • Organization: School of Informatics, The University of Edinburgh
On Saturday 29 September 2007 05:36:10 Stefan O'Rear wrote:
> On Sat, Sep 29, 2007 at 12:26:06AM -0400, Ethan Aubin wrote:
> > Hi,  This might be an obvious question, but is 'forall (A:Set)(x y:A),
> > (x=y)=(y=x)' provable in Coq? - EA
> Equality is a very slippery subject in Coq and other systems based on
> intuitionistic type theories.  Your statement is certainly true if you
> replace the outer = with <-> (split; auto).  In general, it's a bad idea
> to use = on anything other than values of inductive types.
> Stefan
Hi,
I ran across a similar situation recently. A tactic I was reading about tries
to change the goal so that a subterm is equal to a Prop assumption called p.
It then replaces p with True. In other words, it tries to use the following
theorem:
forall (p:Prop), p->p=True.
In Coq, none of the automated tactics do anything if you try to prove this
theorem and I really can't see any useful steps forward. I assume it isn't
true but I can't explain why. If it isn't true, does anyone have a good
explanation as to why it isn't true in Coq but it is in other logics?
Regards,
Sean
