- To: Yevgeniy Makarov <emakarov AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Defining merge sort
- Date: Thu, 8 Nov 2007 13:30:35 +0000
On Wed, Nov 07, 2007 at 11:00:40PM +0100, Yevgeniy Makarov wrote:
> Hello,
> I followed Benjamin's hint, and here's my version of merge on lists of
> natural numbers:
> Require Import List.
> Require Import Compare_dec.
> Fixpoint merge (l1 : list nat) : list nat -> list nat :=
> fix merge_helper (l2 : list nat) :=
> match l1, l2 with
> | nil, nil => nil
> | nil, l => l
> | l, nil => l
> | x1 :: l1, x2 :: l2 =>
> if leb x1 x2
> then x1 :: merge l1 (x2 :: l2)
> else x2 :: merge_helper l2
> end.
Thanks for the code, I didn't quite understand the original hint. This
is a nice trick, I hadn't come across it before.
Thanks all for the help!
Edsko
PS. I've attached my preferred 'symmetric' merge plus a proof that it is
indeed symmetric, in that 'merge l1 l2 = merge l2 l1', for arbitrary
lists l1 l2.
Require Import OrderedType.
Require Import OrderedTypeEx.
Tactic Notation "unsimpl" constr(E) :=
let F := (eval simpl in E) in change F with E.
Module MultiSet (OT : UsualOrderedType).
Fixpoint merge (l1: list OT.t) : list OT.t -> list OT.t :=
fix merge_aux (l2: list OT.t) : list OT.t :=
match (l1, l2) with
| (nil, nil) => nil
| (nil, l2) => l2
| (l1, nil) => l1
| (a1 :: l1_tail, a2 :: l2_tail) =>
match OT.compare a1 a2 with
| LT _ => a1 :: merge l1_tail l2
| EQ _ => a1 :: a2 :: merge l1_tail l2_tail
| GT _ => a2 :: merge_aux l2_tail
end
end.
Lemma not_ltab_ltba : forall a b,
OT.lt a b -> OT.lt b a -> False.
Proof (fun a b H H0 => OT.lt_not_eq _ _ (OT.lt_trans _ _ _ H H0) (OT.eq_refl
a)).
Lemma not_ltab_eqab : forall a b,
OT.lt a b -> OT.eq a b -> False.
Proof (fun a b H H0 => OT.lt_not_eq _ _ H H0).
Lemma not_ltab_eqba : forall a b,
OT.lt a b -> OT.eq b a -> False.
Proof (fun a b H H0 => OT.lt_not_eq _ _ H (OT.eq_sym _ _ H0)).
Hint Resolve not_ltab_ltba not_ltab_eqab not_ltab_eqba : lt_contradictions.
Lemma merge_comm : forall l1 l2,
merge l1 l2 = merge l2 l1.
Proof.
induction l1 ; induction l2 ; simpl ; auto.
case (OT.compare a a0) ; case (OT.compare a0 a) ; intros ;
try (apply False_ind ; eauto with lt_contradictions ; fail).
unsimpl (merge (a0 :: l2) l1).
rewrite IHl1 ; reflexivity.
rewrite e ; rewrite IHl1 ; reflexivity.
unsimpl (merge (a :: l1) l2).
rewrite IHl2 ; reflexivity.
Qed.
End MultiSet.
- [Coq-Club] Defining merge sort, Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Benjamin Werner
Julien Forest
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, Pierre Casteran
- Re: [Coq-Club] Defining merge sort, Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Pierre Courtieu
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, frederic . blanqui
- Re: [Coq-Club] Defining merge sort, Matthieu Sozeau
