- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Defining merge sort
- Date: Wed, 7 Nov 2007 19:26:23 +0000
Hi,
I have been trying to define merge sort (because it should be easy to
prove that merge M1 M2 = merge M2 M1, the property I needed for my sets;
see previous thread). Obviously, merge sort is structurally recursive on
two arguments, so we need (I think!) some trickery to make it work. This
is my attempt so far: I introduce a "substructure" relation on a pair of
lists:
Inductive two_list_sub (A: Set) : (list A * list A) -> (list A * list A) ->
Prop :=
| two_list_sub_l1 : forall (a: A) (l1 l2: list A),
two_list_sub (l1, l2) (a :: l1, l2)
| two_list_sub_l2 : forall (a: A) (l1 l2: list A),
two_list_sub (l1, l2) (l1, a :: l2).
I then prove that this relation is well-founded:
Lemma two_list_sub_well_founded : forall (A: Set),
well_founded (@two_list_sub A).
And then define an iterator like the list_rec iterator but one that works on
pairs of lists:
Definition two_list_induction (A: Set) (P : (list A * list A) -> Set) :
(forall (l: list A), P (nil, l)) ->
(forall (l: list A), P (l, nil)) ->
(forall (l1 l2: list A) (a1 a2: A),
P (l1, a2 :: l2) ->
P (a1 :: l1, l2) ->
P (a1 :: l1, a2 :: l2)) ->
forall (l1 l2: list A), P (l1, l2).
intros.
apply (well_founded_induction (@two_list_sub_well_founded A)).
intros ; destruct x as [l1' l2'] ; destruct l1' ; destruct l2' ; auto.
Defined.
Finally, I define merge sort using the new iterator:
Module SortedList (OT : OrderedType).
Definition merge : (list OT.t * list OT.t) -> list OT.t.
intros.
destruct H as [l1 l2].
apply (two_list_induction (fun _ : (list OT.t * list OT.t) => list OT.t)).
intros ; exact l2.
intros ; exact l1.
intros l1_tail l2_tail a1 a2 l1_rec l2_rec.
case (OT.compare a1 a2) ; intros.
exact (a1 :: l1_rec).
exact (a2 :: l2_rec).
exact l1.
exact l2.
Defined.
This seems to work, but I get stuck when I try to define even the
simplest lemmas about 'merge':
Lemma merge_nil :merge (nil, nil) = nil.
Unfolding merge, and then two_list_induction, and then
well_founded_induction, etc. yields a very big term on the left hand
side, but never one that can be simplified to nil. Am I doing something
stupid?
Thanks!
Edsko
PS. Full development is attached.
Set Implicit Arguments.
Require Import List.
Require Import Wellfounded.
Require Import Omega.
Require Import OrderedType.
Inductive two_list_sub (A: Set) : (list A * list A) -> list A * list A ->
Prop :=
| two_list_sub_l1 : forall (a: A) (l1 l2: list A), two_list_sub (l1, l2) (a
:: l1, l2)
| two_list_sub_l2 : forall (a: A) (l1 l2: list A), two_list_sub (l1, l2)
(l1, a :: l2).
Hint Constructors two_list_sub.
Lemma two_list_sub_acc : forall (A:Set) (l1 l2: list A),
Acc (@two_list_sub A) (l1, l2).
Proof.
cut((forall (n:nat) (A : Set) (l1 l2 : list A), length l1 + length l2 < n
-> Acc (two_list_sub (A:=A)) (l1, l2))).
intuition eauto.
induction n ; intros ; constructor ; intros.
apply False_ind ; omega.
destruct l1 ; destruct l2 ; inversion H0 ; subst ; simpl in * ;
apply IHn ; simpl ; omega.
Defined.
Lemma two_list_sub_well_founded : forall (A: Set), well_founded
(@two_list_sub A).
Proof.
unfold well_founded.
intros.
destruct a as [l1 l2].
apply two_list_sub_acc.
Qed.
P (l1, a2 :: l2) ->
P (a1 :: l1, l2) ->
intros.
Defined.
intros.
intros ; exact l2.
intros ; exact l1.
exact l1.
exact l2.
Defined.
- [Coq-Club] Defining merge sort, Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Benjamin Werner
Julien Forest
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, Pierre Casteran
- Re: [Coq-Club] Defining merge sort, Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Pierre Courtieu
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, frederic . blanqui
- Re: [Coq-Club] Defining merge sort, Matthieu Sozeau
