- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: Julien Forest <forest AT ensiie.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Defining merge sort
- Date: Fri, 9 Nov 2007 13:28:04 +0100
Le Thu, 8 Nov 2007 12:24:16 +0000, Edsko de Vries
a écrit:
> Lemma merge_comm : forall l1 l2,
> merge (l1, l2) = merge (l2, l1).
> (With the "symmetric" merge, this will hold even if the lists aren't
> sorted).
> However, I get stuck when I try to prove this using functional induction:
> Proof.
> intros l1 l2.
> functional induction (merge (l1, l2)).
> functional induction (merge (l2, l1)).
> reflexivity.
Hi
You should not use functional induction with non variable arguments
(as with "induction").
Here is an example of use of functional induction.
Lemma merge_nil : forall x l2,
x= (nil,l2) -> merge x = l2.
intros x.
functional induction (merge x);auto;intros.
inversion H;subst;trivial.
inversion H.
Qed.
Cheers,
Pierre Courtieu
- [Coq-Club] Defining merge sort, Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Benjamin Werner
Julien Forest
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, Pierre Casteran
- Re: [Coq-Club] Defining merge sort, Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Defining merge sort, Pierre Courtieu
Yevgeniy Makarov
- Re: [Coq-Club] Defining merge sort, frederic . blanqui
- Re: [Coq-Club] Defining merge sort, Matthieu Sozeau
