- From: Andrew McCreight <andrew.mccreight AT yale.edu>
- To: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] string comparison
- Date: Wed, 16 Jan 2008 15:30:00 -0500 (EST)
What you want can't be done in the logic (CiC). You could probably write a tactic to do that, but you can't reason about tactics, so that probably isn't useful.
In the metalogic of Twelf you can pattern match against variables, but that's fairly unusual.
-Andrew
On Wed, 16 Jan 2008, Theodoros G. Tsokos wrote:
Dear all,
I'm having the following definition (representing identifiers of a language)
Variable string : Type.
Variables x y z : string.
I'm trying to find a way to compare the above strings, that is the identifiers themselves, not their values, and get a boolean number as an output. That is, something like:
Variables A B : string.
if (A=B) then true else false.
where :
for A= x and B=x it'll give me true, but for A=x and B=y it'll give me false.
I tried to use sumbool, like implemented in Yves Bertot's Semantics Survey [1] :
Variable string_dec : forall a b:string, {a=b}+{a<>b}
but I got really confused.
Thank you very much in advance for your time and help. It's probably a trivial solution so apologize for using the list for something like that.
Regards,
Theo.
[1] http://coq.inria.fr/contribs/Semantics_survey.html
| Theodoros G. Tsokos |
| http://www.cs.bham.ac.uk/~txt |
| School of Computer Science, The University of Birmingham |
| Edgbaston, Birmingham, B15 2TT, United Kingdom |
| "The freedom of speech includes the freedom to shut up" |
| "Democracy: the freedom to say whatever one wants and |
| the capital to implement whatever it wants" |
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] string comparison, Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Andrew McCreight
- Re: [Coq-Club] string comparison, Frédéric Besson
Yves Bertot
- Re: [Coq-Club] string comparison, Yves Bertot
Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Benjamin Werner
