- To: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] string comparison
- Date: Thu, 17 Jan 2008 09:31:07 +0100
On 16 janv. 08, at 20:18, Theodoros G. Tsokos wrote:
Dear all,Do you really want to keep the string type abstract ?
I'm having the following definition (representing identifiers of a language)
Variable string : Type.
Variables x y z : string.
If no, you can use the Coq string library - there is a string_dec function
Require Import String
If yes, you will have to axiomatize further and make the hypothesis of a string comparison function
Variable compare_string : string -> string -> bool.
Variable compare_string_correct : ....
Regards,
Frédéric Besson
- [Coq-Club] string comparison, Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Andrew McCreight
- Re: [Coq-Club] string comparison, Frédéric Besson
Yves Bertot
- Re: [Coq-Club] string comparison, Yves Bertot
Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Benjamin Werner
