- To: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] string comparison
- Date: Thu, 17 Jan 2008 22:26:26 +0100
Theodoros G. Tsokos wrote:
Dear all,If you use the string package provided with Coq 8.1pl2
thank you very much for your replies and your time.
Yves Bertot wrote:
Long answer:Yes, it really helped my understanding (I hope ) in this topic. Thanks for the long answer in specific, it was quite informative.
I hope this helps,
Yves
However, I would like to rephrase, in a way, my question. I knew about the option of creating a string_dec function of type forall x y: string, {x=y}+{x<>y}, as in Yves' Semantics Survey. I'm concerned about the *evaluation* of the clause as well. For example the following:
Coq < Eval compute in (if (string_dec x y) then true else false).
to give me false as an answer, whereas the
Coq < Eval compute in (if (string_dec x x) then true else false).
to give me true. However, in that way I don't get this result.
Apologize for not setting it down properly in my first email, but my aim is to be able to do that kind of evaluations/computations, in order to get a *terminal* result from the evaluation.
Thank you very much in advance again,
Theo.
(I haven't installed the earlier version yet), you have the following behavior.
dizzy:~/talks bertot$ coqtop
Welcome to Coq 8.1pl2 (Oct. 2007)
Coq < Require Import String.
Warning: Notation _ ++ _ was already used in scope string_scope
Coq < Open Scope string_scope.
Coq < Definition x := "a first identifier".
x is defined
Coq < Definition y := "a second identifier".
y is defined
Coq < Eval compute in (if string_dec x x then true else false).
= true
: bool
Coq < Eval compute in (if string_dec x y then true else false).
= false
: bool
Now, if you want to keep x and y as variables, you can't expect "string_dec x y" to go
beyond evaluating as just "string_dec x y", because you don't know what may happen, see here:
Section my.
Variables x y : string.
Hypothesis x_is_y : x = y.
Definition f := if string_dec x y then true else false.
(* you think f should be true? Well, you can prove it! *)
Lemma f_is_true : f = true.
Proof.
unfold f; case (string_dec x y); auto; intros x_is_not_y; case x_is_not_y; exact x_is_y.
Qed.
(* but you can also prove that f is false, here is how. *)
Hypothesis x_is_not_y : x <> y.
Lemma f_is_false : f = false.
Proof.
unfold f; case (string_dec x y); auto; intros; case x_is_not_y; exact x_is_y.
Qed.
(* Of course, we are in an inconsistent environment, but if you let inconsistent hypotheses
interfere with reduction, you cannot preserve strong normalization or the consistency of Coq. *)
(* Now if we leave the section, then two hypotheses are not valid anymore, so we are not
in an inconsistent state anymore. *)
End my.
(* Outside the section the various constants f, f_is_true, and f_is_false are all defined and meaningful!
You can use Check to verify that we have the following types for the constant. *)
f : string -> string -> bool
f_is_true : forall x y : string, x = y -> f x y = true
f_is_false : forall x y : string, x <> y -> f x y = false
Conclusion: if you want string_dec to compute, you have to feed it with real data, not abstract variables.
Any logical hypothesis you make about a variable may be contradicted by some other hypothesis and
it would be foolish to let the evaluation mechanism depend on hypotheses too precisely.
Yves
- [Coq-Club] string comparison, Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Andrew McCreight
- Re: [Coq-Club] string comparison, Frédéric Besson
Yves Bertot
- Re: [Coq-Club] string comparison, Yves Bertot
Theodoros G. Tsokos
- Re: [Coq-Club] string comparison, Benjamin Werner
