- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Need advice (proof about Huntington's postulates)
- Date: Mon, 21 Jan 2008 14:40:40 +0100
I dont't know if it helps, but if you add some notion of "value" and computation,
Function value (a:trm):bool :=
match a with true => Datatypes.true
| false => Datatypes.false
| or b c => Bool.orb (value b) (value c)
| and b c => Bool.andb (value b) (value c)
| not b => Bool.negb (value b)
end.
You can prove by induction the following lemma:
Lemma L1 : forall a b, equiv a b -> value a = value b.
induction 1;simpl; auto.
Qed.
then by discrimination, prove that ~ equiv true false.
Pierre
Edsko de Vries a écrit :
Hi,
I have formalized Huntington's postulates (commutativity,
distributivity, identity, complement, and the closure and structural
rules) and proven the most common derived properties; the full
development can be found at
http://www.cs.tcd.ie/~devriese/coq
Unfortunately, I need the following axiom:
Axiom true_false_distinct : ~ equiv true false.
(where 'equiv' is the equivalence relation resulting from Huntington's
postulates). Now, Huntington actually needs this axiom too, but that is
because he needs to stipulate that 'true' and 'false' are two distinct
elements in the boolean algebra. Since 'true' and 'false' in my
formalization are two constructors for the 'trm' inductive datatype (and
therefore provably distinct), I feel that I should be able to *prove*
true_false_distinct from the postulates--but all my attempts so far have
failed. I think I need to strengthen the lemma to be able to prove
true_false_distinct, but I'm not sure how. Any advice would be
appreciated!
Thanks,
Edsko
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Need advice (proof about Huntington's postulates), Edsko de Vries
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Pierre Casteran
Edsko de Vries
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Benjamin Werner
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Carlos . SIMPSON
Edsko de Vries
