- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Need advice (proof about Huntington's postulates)
- Date: Mon, 21 Jan 2008 14:13:00 +0000
On Mon, Jan 21, 2008 at 02:40:40PM +0100, Pierre Casteran wrote:
> I dont't know if it helps, but if you add some notion of "value" and
> computation,
> Function value (a:trm):bool :=
> match a with true => Datatypes.true
> | false => Datatypes.false
> | or b c => Bool.orb (value b) (value c)
> | and b c => Bool.andb (value b) (value c)
> | not b => Bool.negb (value b)
> end.
> You can prove by induction the following lemma:
> Lemma L1 : forall a b, equiv a b -> value a = value b.
> induction 1;simpl; auto.
> Qed.
> then by discrimination, prove that ~ equiv true false.
Thanks very much--nice and easy solution! Much appreciated.
Can you explain (intuitively) why a direct solution is not possible (or
more difficult?)
Edsko
- [Coq-Club] Need advice (proof about Huntington's postulates), Edsko de Vries
- Re: [Coq-Club] Need advice (proof about Huntington's postulates),
Pierre Casteran
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Edsko de Vries
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Pierre Casteran
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Benjamin Werner
- Re: [Coq-Club] Need advice (proof about Huntington's postulates), Carlos . SIMPSON
Pierre Casteran
