- To: Vincent Aravantinos <vincent.aravantinos AT gmail.com>
- Cc: gang chen <gangchen_sh AT yahoo.com>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?
- Date: Thu, 14 Feb 2008 10:26:47 +0000
- Organization: Systems Research Group, UCD Dublin
On Thu, 14 Feb 2008 10:54:17 +0100
Vincent Aravantinos
wrote:
> Assume you are given two functions (f:Prop -> nat) and (g:nat ->
> Prop), and then define a F like this:
> Definition F (P:Prop) : Prop -> Prop := g (1 + f P).
> I don't see any reason why such a function would respect your
> conjecture.
But how can you define a function f : Prop -> nat which yields
different numbers for different propositions, in Coq? You can't do case
analysis on Props.
Robin
- [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?, gang chen
- Re: [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?,
Vincent Aravantinos
- Re: [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?, Robin Green
Vincent Aravantinos
Gyesik Lee
- Re: [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?, Andreas Abel
- Re: [Coq-Club] is "(A<->B)->((F A)<->(F B))" provable ?, Bruno Barras
Gyesik Lee
Vincent Aravantinos
Vincent Aravantinos
