- To: "Michael Day" <mikeday AT yeslogic.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Second order unification problem?
- Date: Wed, 9 Apr 2008 14:49:54 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=nZ+k1BegAnZjIFfADIWn7hG3+138/pqSyvnU5LCb2JKHjHXI5vB/qMfnXJ9hpC3nNAhdLq/8Ac5yOgEl4L2H3+6WJLQy+g1wVySZgNISZFXE+5v70+VLtAaDUIY2TCqhNNOH5tyF5D0yVE10phrpcEkvjuvhft0U3d+iPwFWais=
Hi,
If you look at the induction principle generated for your inductive
bit vectors, you see that it applies to a predicate P over bit vectors
of every possible size :
bits_ind
: forall P : forall n : nat, bits n -> Prop,
P 0 Bnil ->
(forall (n : nat) (b : bool) (b0 : bits n),
P n b0 -> P (S n) (Bcons n b b0)) ->
forall (n : nat) (b : bits n), P n b
The thing here is you only want to prove something for bit vectors of
size 0, and Coq cannot infer a suitable predicate of type "forall (n :
nat) (b : bits n), P n b" such that P 0 b is precisely your goal. You
can help coq by filling in the missing cases (n <> 0) manually in the
following way :
Definition P : forall n, bits n -> Prop :=
fun n =>
match n return (bits n -> Prop) with
| 0 => (fun b => b = Bnil)
| _ => (fun b => True)
end.
This defines a predicate P with the correct type such that P 0 is
precisely your lemma. Note that it is necessary to use dependent
matching since the equation b = Bnil only makes sense when n = 0. For
the other branch, we can use True : this makes it easily provable and
we are not interested in that branch anyway. Now, you can prove your
lemma this way :
Theorem only_one_bits0 : forall (bs:bits 0), bs = Bnil.
Proof.
intro b; change (P O b).
induction bs. (* this time, unification succeeds because we
explicited the suitable P *)
simpl; reflexivity. (* the case you are interested in *)
simpl; trivial. (* the trivial case for n <> 0 *)
Qed.
You dont have to use an auxiliary definition of P and an explicit
"change" tactic, you might as well use "apply bits_ind with P := ..."
directly when proving your lemma. If you end up doing this several
times, you can also define an inductive principle for bits 0 by
generalizing the predicate P above for any predicate of type bits 0 ->
Prop.
I dont know if there s a more elegant or quicker way to do this, but I
hope this helps.
Stephane L.
http://www.lri.fr/~lescuyer/
On Wed, Apr 9, 2008 at 1:58 PM, Michael Day
wrote:
> Hi,
> Sorry to bother the list again, but I've been reading the manual and can't
> find any explanation of this error message:
> User error: Cannot solve a second-order unification problem.
> I get this error when attempting to prove the following theorem:
> Inductive bits : nat -> Set :=
> | Bnil : bits 0
> | Bcons : forall n:nat, bool -> bits n -> bits (S n).
> Proof.
> intro bs.
> case bs. (* fails *)
> It seems clear to me that a value of type "bits 0" has to be Bnil, as the
> other constructor has type "bits (S n)", but I can't figure out how to
> express this. Any help would be greatly appreciated.
> Best regards,
> Michael
> Print XML with Prince!
> http://www.princexml.com
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] Second order unification problem?, Michael Day
- Re: [Coq-Club] Second order unification problem?, Stéphane Lescuyer
