coq-club - Re: [Coq-Club] functional induction and nested list's
chronological Thread
  • To: Adriaan Moors <adriaan AT cs.kuleuven.be>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] functional induction and nested list's
  • Date: Wed, 9 Apr 2008 16:14:20 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=date:from:to:cc:subject:message-id:in-reply-to:references:organization:x-mailer:mime-version:content-type:content-transfer-encoding:sender; b=lPMVPgXNnpL4Pyi2Ae/i4KXla2xzbQlQrdr0TxF+HTbcARygKICzYsGuETxc9/5I6WChd3WlwmniAOP5/v9NwvNluK4xyQHwwr81Xr/4umU6G3WdyqrtPL5PsDV43REHhGvuHyOuJnelkz0MCzPeykN9ufJOCbvqa2AedIrEb24=
  • Organization: CNAM
Dear Adriaan,
On Wed, 9 Apr 2008 10:12:03 +0000 (UTC)
Adriaan Moors
 wrote:
> Dear Club,
> I'm trying to do functional induction on my substitution function. My
> current
> definition uses List.map to define substitution on a list of members in
> terms
> of substitution on a single member. This breaks the generation of the
> induction principle, which I can live with. Thus, to be able to generate the
> induction principle automatically, I simplified my definition to the
> following, which still does not work:
> Require Import List.
> Inductive trm : Set :=
>   | new : typ -> trm
> with typ : Set :=
>   | strct : list member -> typ
> with member : Set :=
>   | membr : typ -> trm -> member.
> Function subst_trm (e : trm) {struct e} : trm :=
>   match e with
>     | new T => new (subst_typ T)
>   end
> with subst_typ (e : typ) {struct e} : typ :=
>   match e with
>     | strct mems => strct (subst_mems mems)
>   end
> with subst_mem  (e : member) {struct e} : member :=
>   match e with
>     | membr T rhs => membr (subst_typ T) (subst_trm rhs)
>   end
> with subst_mems (e : list member) {struct e} : list member :=
>   match e with
>     | nil => nil
>     | cons m ms => cons (subst_mem m) (subst_mems ms)
> (* Error:
> Recursive call to subst_mem has principal argument equal to
> "m"
> instead of ms
>   end.
This is not a Function limitation but a Fixpoint one.
Coq only allows the user to define a mutual recursive functions over
mutually recursively defined inductives. So that you can not defined
subst_mems in the same block as the three other functions.
In order not to inline the definition of lists, you can use a well-know trick
constiting in inlining
the definition of subst_mems itself as follows:
Fixpoint subst_trm (e : trm) {struct e} : trm :=
  match e with
  end
  match e with
    | strct mems =>
      let subst_mems :=
        fix subst_mems (mems:list member) {struct mems} :=
        match mems with
          | nil => nil
        end
        in
  end
  match e with
  end
But this time you will lose the possibility of using Function since this
feature does not support (and will not support for probably a long time)
so called local recursive definition.
Best regards,
Julien Forest
