- To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] proofs involving variables appeared from matching
- Date: Sun, 27 Apr 2008 19:51:20 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type:Message-ID; b=nBwnTk5w2WjIR+SngbBLfpCty4bUgXYTfUvmSYxzYFzqjG7VWQlXffymkIo7b7VGu3uKjKp+6TvW9QzFYp7y9K3xRRZE3x55cYBuYK9LxzvlbNBWZHPFTHc+DCTDsrZpSf1kZ68oCB/oN8jNkr4VlMKK8N+6P0ycBRZfayXObxg=;
I apologize for the potential amount of ignorance
in this question, justified by the fact that I am a beginner with Coq.
Consider the definition:
Definition Less n := {j | j < n}.
And the following part of definition (some code is
omitted)
Fixpoint SupL (n:nat) (f:Less n -> nat) {struct
n} : nat :=
match n with ... |S n' => ... f (exist (fun j => j < n) n' (lt_n_Sn n')))... end. where
lt_n_Sn: forall n : nat, n < S n
The function SupL n f tries to compute the supremum
of {f 0, f 1,...,f (n-1)}, and employs the lemma le_n_Sn in an attempt to build
the necessary proof of n' < n. However,
the definition of SupL does not type check, because
(I quote):
<< The term "lt_n_Sn n' " has type "n' < S
n' " while it is expected to have type
"(fun j : nat => j < n) n' " >> Even though I understand pragmatically what the
problem is (n is not identified to S n' ), I do not know how to fix it, since I
do not know how to produce a proof that the "volatile" n' is less than n.
My more general question is: after a match is
performed, what facts are available about the matched term and the matching
pattern?
Thank you in advance for any hint on this,
Andrei Popescu |
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
- [Coq-Club] proofs involving variables appeared from matching, Andrei Popescu
- Re: [Coq-Club] proofs involving variables appeared from matching, Pierre Casteran
Edsko de Vries
- Re: [Coq-Club] proofs involving variables appeared from matching, Matthieu Sozeau
- Re: [Coq-Club] proofs involving variables appeared from matching, Andrei Popescu
