coq-club - Re: [Coq-Club] proofs involving variables appeared from matching
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: uuomul AT yahoo.com
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] proofs involving variables appeared from matching
  • Date: Mon, 28 Apr 2008 11:36:45 +0200
Hi,
I'm not sure it answers correctly your mail, but I cases like yours, it's often easier
to build functions interactively, and look at the built term.
If I want to build a function of the form you wrote, it can be done as follows:
Pierre
Definition Less n :={j| j< n}.
Definition restrict (n:nat)(f : Less (S n) -> nat) : Less n -> nat.
Proof.
intros n f X.
apply f.
case X;intros p Hp.
exists p;auto.
Defined.
Print restrict.
Require Import Max.
Definition supL (n:nat)(f:Less n -> nat):nat.
intro n;elim n.
intros;exact 0.
intros p Supp fp.
refine (max (fp (exist _ p _)) (Supp (restrict _ fp))).
auto.
Defined.
Print supL.
Andrei Popescu a écrit :
I apologize for the potential amount of ignorance in this question, justified by the fact that I am a beginner with Coq.
Consider the definition:
Definition Less n := {j | j < n}.
And the following part of definition (some code is omitted)
Fixpoint SupL (n:nat) (f:Less n -> nat) {struct n} : nat :=
match n with
|S n' => ... f (exist (fun j => j < n) n' (lt_n_Sn n')))...
end.
where
lt_n_Sn: forall n : nat, n < S n
The function SupL n f tries to compute the supremum of {f 0, f 1,...,f (n-1)}, and employs the lemma le_n_Sn in an attempt to build the necessary proof of n' < n. However,
the definition of SupL does not type check, because (I quote):
<< The term "lt_n_Sn n' " has type "n' < S n' " while it is expected to have type
"(fun j : nat => j < n) n' " >>
Even though I understand pragmatically what the problem is (n is not identified to S n' ), I do not know how to fix it, since I do not know how to produce a proof that the "volatile" n' is less than n. My more general question is: after a match is performed, what facts are available about the matched term and the matching pattern?
Thank you in advance for any hint on this,
Andrei Popescu
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. <http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ%20> -------------------------------------------------------- Bug reports: http://logical.futurs.inria.fr/coq-bugs Archives: http://pauillac.inria.fr/pipermail/coq-club http://pauillac.inria.fr/bin/wilma/coq-club Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
