- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] proofs involving variables appeared from matching
- Date: Mon, 28 Apr 2008 12:26:55 +0200
Hello,
Another alternative would be to use the Program extension and write:
Program Fixpoint SupL (n:nat) (f:Less n -> nat) {struct n} : nat :=
match n with
| 0 => 0
| S n' => f n'
end.
You can look at the definition of SupL to see how equalities between the matched term and the patterns are kept in each branch. They are used to discharge the proof obligation arising from the coercion of n' from nat to Less n at the "f n'" call. Program is documented in the manual.
Matthieu Sozeau
http://www.lri.fr/~sozeau
- [Coq-Club] proofs involving variables appeared from matching, Andrei Popescu
- Re: [Coq-Club] proofs involving variables appeared from matching, Pierre Casteran
Edsko de Vries
- Re: [Coq-Club] proofs involving variables appeared from matching, Matthieu Sozeau
- Re: [Coq-Club] proofs involving variables appeared from matching, Andrei Popescu
