coq-club - Re: [Coq-Club] how to define (very) dependent numeric sums
chronological Thread
  • To: popescu2 AT uiuc.edu
  • Cc: roconnor AT theorem.ca, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] how to define (very) dependent numeric sums
  • Date: Wed, 07 May 2008 10:35:46 +0200
 wrote:
Hello,
Maybe it is just my ignorance about Coq speaking now, but working with boolean predicates P : Less n -> bool does not seem to help either, since then the functions f would be in f : {i : Less n | P i = true} -> nat and after matching P n' with true I do not seem to have access to a proof of P i = true in order to apply f to n'.
(In this and the previous message, I have identified elements of Less n with elements
of nat, in the "Program" style, to keep the ideas clear.)
Regards, Andrei
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Dear Andrei,
Since you are talking about an algorithm, you solution needs to be composed of
algorithms. However, neither Less nor P are algorithms: they are types. Less
is a type for algorithms, in a sense (algorithms that compute a number together with
a guarantee that the number satisfies smaller than n) and P is not even a type for
algorithms. To progress, you need to have an algorithm corresponding to P, this
is why Russell proposed that you should have a boolean algorithm.
Now, if you want to define a recursive function, you have several approaches.
The "old-fashioned" approach is to define the function directly as a Fixpoint,
but for this the type Less n is not suitable, because it does not exhibit any
recursive structure. It will be better to define the function as a recursive function
over nat. However, as you rightly point out, if take an arbitrary natural number
you first have to check whether this natural number does satisfy the Less predicate
and the P predicate. For the Less predicate, this can be granted by assumption,
because you know in advance that you started with an element that was already
the first component of an element in type {i : Less n | P i = true}, but in the
recursive call, you will need to have that any predecessor i' of (the first component of)
i also satisfy  the property (i' < n).   This can be given by the following
theorem, provable using omega, or any other good manual effort.
Lemma lm : forall i', S i' < n -> i' < n.
Now to take only the elements that satisfy P i = true, you still need to call an algorithm,
but in this setting, P is an algorithm but it cannot be called directly called on natural
numbers, because P takes as input elements of Less n. So you need to reconstruct
an element of Less n from an element of nat...
Require Import Arith Omega.
Section Russell_for_Andrei_according_to_Yves.
Variable n: nat.
Definition Less (n:nat) : Set := {i | i < n}.
Variable P : Less n -> bool.
Variable f : {i : Less n | P i = true}->nat.
Lemma lm: forall i', S i' < n -> i' < n.
intros; omega.
Qed.
Fixpoint sum (k:nat) : k < n -> nat :=
 match k return k < n -> nat with
   0 => fun h' : 0 < n =>
   let v0:Less n := exist (fun x => x < n) 0 h' in
   match P v0 as b return P v0 = b -> nat with
true => fun h': P v0 = true => f (exist (fun i : Less n => P i = true) v0 h')
   | false => fun _ => 0
   end (refl_equal (P v0))
 | S k' => fun h: S k' < n =>
   let vk := exist (fun x => x < n) (S k') h in
   let vpred := sum k' (lm k' h) in
     match P vk as b return P vk = b -> nat with
       true => fun h' : P vk = true =>
       f (exist (fun i => P i = true) vk h') + vpred
     | false => fun _ => vpred
     end (refl_equal (P vk))
 end.
Definition s : Less n -> nat :=  fun x => let (k, h) := x in sum k h.
The function s is what you want.
This looks complicated, but you can make simpler by using tactics:
Definition s2 : Less n -> nat.
intros [k]; induction k; intros h.
assert (v0 : Less n) by (exists 0; exact h).
case_eq (P v0); intros h'.
apply f; exists v0; exact h'.
exact 0.
assert (vk : Less n) by (exists (S k); exact h).
assert (vpred:nat) by (apply IHk; apply lm; assumption).
case_eq (P vk); intros h'.
assert (fvk:nat) by (apply f; exists vk; exact h').
exact (fvk + vpred).
exact vpred.
Defined.
The algorithmic intuition is quite lost in the tactics. I think you can do better with Mathieu Sozeau's
new Program facilities, but I haven't played with it yet.
Another, more systematic approach, is exhibited in the ssreflect package: the type Less n is actually
defined as "ordinal n" and the operation of summing all elements satisfying a predicate is already
provided in the package (in a file called bigops). I suggest you have a look.
http://www.msr-inria.inria.fr/Projects/math-components/math-components-index
Yet another solution is to keep P as a Prop predicate and to suppose the existence of a sumbool-typed
predicate:
Variable n: nat.
Variable P : Less n -> Prop.
Variable P_dec : forall x, {P x}+{~P x}.
Variable f : {i : Less n | P i}->nat.
intros; omega.
Qed.
   match P_dec v0 with
     left h' =>
   | _ => 0
   end
     match P_dec vk with
       left h' =>
     |  _ => vpred
     end
 end.
I prefer this solution, which also has the advantage that proofs on this function are easier.
Yet another solution relies on the "Function package" here is the example (this works on
a very recent svn version of Coq).
Require Import Arith Omega Recdef.
Variable n: nat.
Definition is_zero (k:Less n) : bool :=
 match k with (exist 0 _) => true | _ => false end.
intros; omega.
Qed.
Definition Less_pred (k:Less n) : Less n :=
 match k with (exist (S k) h) =>
   exist (fun x => x < n) k (lm k h)
 | _ => k
 end.
Definition Less_to_nat (k: Less n) : nat :=
 match k with exist k _ => k end.
Definition mk_P (k: Less n) (h: P k) :=
  exist (fun i => P i) k h.
Function s4 (k:Less n) {measure Less_to_nat} : nat :=
 if is_zero k then
   match P_dec k with
     left h => f (mk_P k h)
   | _ => 0
   end
 else
   match P_dec k with
   | _ => 0
   end +s4 (Less_pred k).
intros [k]; case k; simpl; intros; discriminate || omega.
Defined.
I like the fourth solution because the way you write the algorithm is close
to your initial intent. Moreover, Function produces a collection of nice theorems
that will make all reasoning about the function much easier (especially using functional induction).
Still there are a few things that are unpleasant:
* We need to duplicate code, because Function does not like let .. = .. in .. constructs.
* We need to define mk_P because Function does like lambda abstractions.
Yves
