- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] how to define (very) dependent numeric sums
- Date: Wed, 7 May 2008 15:02:44 +0200
Le 7 mai 08 à 10:35, Yves Bertot a écrit :
popescu2 AT uiuc.edu
wrote:
Hello,
Maybe it is just my ignorance about Coq speaking now, but working with boolean predicates P : Less n -> bool does not seem to help either, since then the functions f would be in f : {i : Less n | P i = true} -> nat and after matching P n' with true I do not seem to have access to a proof of P i = true in order to apply f to n'.
(In this and the previous message, I have identified elements of Less n with elements of nat, in the "Program" style, to keep the ideas clear.)
Regards, Andrei
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
<snip/>
The algorithmic intuition is quite lost in the tactics. I think you can do better with Mathieu Sozeau's
new Program facilities, but I haven't played with it yet.
Indeed you could have:
Require Import Program.
Notation Less n := {i | i < n}.
Section Sum'.
Variables (n : nat) (P : Less n -> bool) (f : {i : Less n | P i = true} -> nat).
Program Fixpoint sum' (n' : Less n) { measure proj1_sig } : nat :=
match n' with
| 0 => 0
| S n'' =>
let r := sum' n'' in
if dec (P n') then f n' + r else r
end.
Next Obligation.
Proof.
rewrite <- H. pi.
Qed.
End Sum'.
Note that it uses the "dec" combinator which lifts a boolean to a sumbool (forall b : bool, { b = true } + { b = false }) so that you get the hypothesis [P n' = true] in the first branch. Another equivalent solution would be to explicitely pattern-match on the result of [P n']:
let r := sum n'' in match P n' with true => f n' + r | false => r end.
Then Program would generate the equality [P n' = true] as well. One could also develop a P_dec variant.
Hope this helps,
-- Matthieu
- [Coq-Club] how to define (very) dependent numeric sums, Andrei Popescu
- Re: [Coq-Club] how to define (very) dependent numeric sums,
roconnor
- Re: [Coq-Club] how to define (very) dependent numeric sums, Carlos . SIMPSON
- <Possible follow-ups>
popescu2
Yves Bertot
- Re: [Coq-Club] how to define (very) dependent numeric sums, Matthieu Sozeau
Yves Bertot
- Re: [Coq-Club] how to define (very) dependent numeric sums, popescu2
roconnor
