- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Vector head/tail proof
- Date: Mon, 26 May 2008 12:39:21 +0100
Hi,
I was playing around with the trick posted by James McKinna a while back on
definition of head and tail on vectors without relying on inversion:
Section Vectors.
Variable (A : Set).
Inductive vec : nat -> Set :=
| vnil : vec 0
| vcons : forall n, A -> vec n -> vec (S n).
Definition vhead (n : nat) (v : vec (S n)) : A :=
match v in vec m return (match m with 0 => True | S n' => A end) with
| vnil => I
| vcons _ head _ => head
end.
Definition vtail (n : nat) (v : vec (S n)) : vec n :=
match v in vec m return (match m with 0 => True | S n' => vec n' end) with
| vnil => I
| vcons _ _ tail => tail
end.
This works quite nicely, but I got stuck in the following proof:
Lemma vec_decompose : forall (n : nat) (v : vec (S n)),
v = vcons n (vhead n v) (vtail n v).
Any hints?
Thanks,
Edsko
- [Coq-Club] Vector head/tail proof, Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof,
frederic . blanqui
- Re: [Coq-Club] Vector head/tail proof, Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof, Pierre Castéran
Matthieu Sozeau
Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof, Matthieu Sozeau
Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof, Hugo Herbelin
frederic . blanqui
