- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Vector head/tail proof
- Date: Mon, 26 May 2008 14:11:06 +0200
Le 26 mai 08 à 13:39, Edsko de Vries a écrit :
Hi,
Hi,
I was playing around with the trick posted by James McKinna a while back on
definition of head and tail on vectors without relying on inversion:
Section Vectors.
Variable (A : Set).
Inductive vec : nat -> Set :=
| vnil : vec 0
| vcons : forall n, A -> vec n -> vec (S n).
Definition vhead (n : nat) (v : vec (S n)) : A :=
match v in vec m return (match m with 0 => True | S n' => A end) with
| vnil => I
| vcons _ head _ => head
end.
Definition vtail (n : nat) (v : vec (S n)) : vec n :=
match v in vec m return (match m with 0 => True | S n' => vec n' end) with
| vnil => I
| vcons _ _ tail => tail
end.
This works quite nicely, but I got stuck in the following proof:
Lemma vec_decompose : forall (n : nat) (v : vec (S n)),
v = vcons n (vhead n v) (vtail n v).
I think you can't avoid using inversion there, especially given the fact that the goal mentions [v] itself.
[dependent inversion] can't do it, but we know how to get around that using so-called "Ford"-induction due to Conor McBride, available in Coq (trunk) as the [dependent induction] tactic.
Require Import Coq.Program.Equality.
Proof.
intros.
dependent induction v.
simpl.
reflexivity.
Qed.
The same can be achieved without special tactics using:
Require Import JMeq.
Proof.
intros.
refine ((_
:forall (gen_x : nat) (v0 : vec gen_x),
JMeq v0 v ->
gen_x = S n -> v = vcons n (vhead n v) (vtail n v))
(S n) v (JMeq_refl v) (refl_equal (S n))).
induction v0 ; intros Hv Hx ; subst.
discriminate.
inversion Hx ; subst.
apply JMeq_eq in Hv. subst.
simpl.
reflexivity.
Qed.
Note the use of heterogeneous equality to keep the equality between [v] and the generalized [v0] variable.
Hope this helps,
Matthieu Sozeau
http://www.lri.fr/~sozeau
- [Coq-Club] Vector head/tail proof, Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof,
frederic . blanqui
- Re: [Coq-Club] Vector head/tail proof, Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof, Pierre Castéran
- Re: [Coq-Club] Vector head/tail proof, Matthieu Sozeau
Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Vector head/tail proof, Hugo Herbelin
frederic . blanqui
