coq-club - Re: [Coq-Club] Vector head/tail proof
chronological Thread
  • From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Vector head/tail proof
  • Date: Mon, 26 May 2008 21:50:40 +0200
Hi,
> I was playing around with the trick posted by James McKinna a while back on
> definition of head and tail on vectors without relying on inversion:
> Section Vectors.
> Variable (A : Set).
> Inductive vec : nat -> Set :=
>   | vnil : vec 0
>   | vcons : forall n, A -> vec n -> vec (S n).
> Definition vhead (n : nat) (v : vec (S n)) : A :=
>   match v in vec m return (match m with 0 => True | S n' => A end) with
>   | vnil => I
>   | vcons _ head _ => head
>   end.
> Definition vtail (n : nat) (v : vec (S n)) : vec n :=
>   match v in vec m return (match m with 0 => True | S n' => vec n' end) with
>   | vnil => I
>   | vcons _ _ tail => tail
>   end.
Just to anticipate on a modest feature of the forthcoming version 8.2
(we hope to be able to announce the beta version in one or two weeks),
in easy cases as above, it will be possible to omit the return
statement and the contradictory matching clause (and this will produce
about the same code as explicitly given above).
Section Vectors.
Set Implicit Arguments.
Variable (A : Set).
  | vnil : vec 0
Definition vhead n (v : vec (S n)) :=
  match v with
  end.
Definition vtail n (v : vec (S n)) :=
  match v with
  end.
Hugo Herbelin
