- From: Vladimir Komendantsky <Vladimir.Komendantsky AT sophia.inria.fr>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] The 'Function' feature anomaly.
- Date: Wed, 28 May 2008 13:53:00 +0200
Well, I tried to run the snippet below in the svn version of Coq and everything went fine. There was no anomaly.
Vladimir
Hermann Lehner wrote:
Hello all,
Some time ago (Mon, 30 Jul 2007 18:07:18 +0200), J.-F. Dufourd came across the following issue.
---snip----
Function div(a b:nat){measure (fun m:nat=>m) a}:nat:=
if eq_nat_dec b 0 then 0
else if (le_lt_dec b a) then (div (a-b) b) + 1 else 0.
Proof. intros. omega. Defined.
is refused with the message:
"Anomaly: Cannot create equation Lemma. Please report".
---snip----
Anyone having an answer on that, as I have the same problem with a much larger definition. The little example above still does not work with Coq 8.1pl3.
Does someone know which part of the function definition triggers this anomaly, so that it can be bypassed?
Thanks!
Best regards
Hermann Lehner
- [Coq-Club] The 'Function' feature anomaly., Hermann Lehner
- Re: [Coq-Club] The 'Function' feature anomaly., Vladimir Komendantsky
- Re: [Coq-Club] The 'Function' feature anomaly., Jean-Francois Dufourd
