- From: Jean-Francois Dufourd <dufourd AT dpt-info.u-strasbg.fr>
- To: Hermann Lehner <hermann.lehner AT inf.ethz.ch>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] The 'Function' feature anomaly.
- Date: Wed, 28 May 2008 15:05:19 +0200
Hello Hermann,
Yves Bertot knows the solution, but the bug has yet to be corrected in a next version of Coq.
Sincerely,
J.-F. Dufourd
Hermann Lehner a écrit :
Hello all,
Some time ago (Mon, 30 Jul 2007 18:07:18 +0200), J.-F. Dufourd came across the following issue.
---snip----
Function div(a b:nat){measure (fun m:nat=>m) a}:nat:=
if eq_nat_dec b 0 then 0
else if (le_lt_dec b a) then (div (a-b) b) + 1 else 0.
Proof. intros. omega. Defined.
is refused with the message:
"Anomaly: Cannot create equation Lemma. Please report".
---snip----
Anyone having an answer on that, as I have the same problem with a much larger definition. The little example above still does not work with Coq 8.1pl3.
Does someone know which part of the function definition triggers this anomaly, so that it can be bypassed?
Thanks!
Best regards
Hermann Lehner
begin:vcard fn;quoted-printable:Jean-Fran=C3=A7ois Dufourd n;quoted-printable:Dufourd;Jean-Fran=C3=A7ois org:University of Strasbourg;LSIIT - UMR CNRS 7005 title:Professor in Computer Science tel;work:(+33) 3 90 24 45 55 version:2.1 end:vcard
- [Coq-Club] The 'Function' feature anomaly., Hermann Lehner
- Re: [Coq-Club] The 'Function' feature anomaly., Vladimir Komendantsky
- Re: [Coq-Club] The 'Function' feature anomaly., Jean-Francois Dufourd
