- From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- To: frederic.blanqui AT loria.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] user-defined tactic in some hypothesis
- Date: Fri, 30 May 2008 11:46:26 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=BSMWpNCJtJfHzHZNYDhIx0aU/NbzUujae2G0eaeRbuVnDNObIRDlAiWLMg7gt+FBzHKCNgRNsKaxdv5G0WzenOx2wHizqBH3mjKSpfoE1C5Mhc5asBrs5hJF+miCX5TSu0ZU898vAWrC7Vg9rHcsvXaCRYjXkVQoDl8o2WxOrhQ=
in a context h1 .. hn |- G, by seeing the targeted hypothesis hi like a goal in the context h1 .. hi-1 |- hi ?I strongly doubt it would yield correct tactics (hi is not a consequence of the h1...hi-1). However I'd love to see something coming out of it.
thank you very much for this tip. unfortunately, it does not work:This is probably because it defines "mytac" as a keyword. I suggest the following course of action to get what you want :
Ltac mytac := ...
Tactic Notation "mytac" "in" ident(H) := ...
after this tactic definition, it seems that "mytac" must always be followed by "in". otherwise we get a syntax error.
in built-in tactics, the "in" is optional...
Tactic Notation "mytac" := mytac.
Tactic Notation "mytac" "in" hyp(H) := ... .
This should work (by the way "hyp(H)" is better than "ident(H)" for that purpose) the way you expect it to.
Arnaud Spiwack
- [Coq-Club] Coq Feature Requests, Michael Day
- [Coq-Club] user-defined tactic in some hypothesis,
frederic . blanqui
- Re: [Coq-Club] user-defined tactic in some hypothesis,
Yves Bertot
- Re: [Coq-Club] user-defined tactic in some hypothesis, frederic . blanqui
Andrew McCreight
frederic . blanqui
- Re: [Coq-Club] user-defined tactic in some hypothesis, Arnaud Spiwack
frederic . blanqui
Yves Bertot
frederic . blanqui
