- To: Johannes Waldmann <johannes AT albapasser.de>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] hierarchical library names and directory layout
- Date: Fri, 6 Jun 2008 14:16:03 +0200 (CEST)
On Tue, 3 Jun 2008, Johannes Waldmann wrote:
I was starting with the naive expectation that "Require Foo.Bar.Baz"
leads to reading the file Foo/Bar/Baz.v(o)
note that such a policy may create new ambiguities:
if you have a file Foo.v in which you define a Module Bar in which you define a module Baz,
and a directory Foo in which you have a file Bar.v in which you define a module Baz.
- [Coq-Club] hierarchical library names and directory layout, Johannes Waldmann
- Re: [Coq-Club] hierarchical library names and directory layout, frederic . blanqui
- Re: [Coq-Club] hierarchical library names and directory layout, Johannes Waldmann
- Is there -pack option? (was [Coq-Club] hierarchical library names and directory layout),
Keiko Nakata
- Re: Is there -pack option? (was [Coq-Club] hierarchical library names and directory layout),
frederic . blanqui
- [Coq-Club] Re: Is there -pack option?, Keiko Nakata
frederic . blanqui
