coq-club - Re: Is there -pack option? (was [Coq-Club] hierarchical library names and directory layout)
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: Is there -pack option? (was [Coq-Club] hierarchical library names and directory layout)
  • Date: Wed, 18 Jun 2008 15:46:30 +0200 (CEST)
On Wed, 18 Jun 2008, Keiko Nakata wrote:
Is there a tool or extension which packs several Coq object files into a
single file
containing the object files as sub-modules, a la Ocaml's -pack option?
i am not sure whether you need such an option in coq: in contrast with ocamlc, there is no linking phase in coqc.
I am looking for some information or a tutorial on how (qualified)
Coq library names are mapped to locations in a file system,
and how this should be used to structure larger Coq projects.
I have been having the same and related problems.
I had several files with the same name and used the file system's hierarchy
to organize the name space. Then my life became complicated;
I miss at least the -pack option as supported in Ocaml.
(the -pack option combines specified object files, packing them in a single
file
containing the object files as sub-modules:
http://caml.inria.fr/pub/docs/manual-ocaml/manual022.html)
I ended up in giving distinct names to distinct files;
my life has become easier, but I am not very happy.
this is also the solution we adopted in http://color.loria.fr/. and to make the life even easier, every thing is compiled using the option
-R <directory_where_CoLoR_is> CoLoR
(instead of using many options like "-I dir" or "-I dir/subdir" etc.)
after that, people willing to import CoLoR modules just have to use this option too, or to use the following command:
Add Rec LoadPath "<directory_where_CoLoR_is" as CoLoR.
which can be put in the ~/.coqrc file.
