coq-club - [Coq-Club] Re: Is there -pack option?
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: Is there -pack option?
  • Date: Wed, 18 Jun 2008 23:44:12 +0900 (JST)
Thank you for the suggestion.
> > Is there a tool or extension which packs several Coq object files into a
> > single file
> > containing the object files as sub-modules, a la Ocaml's -pack option?
> i am not sure whether you need such an option in coq: in contrast with
> ocamlc,
> there is no linking phase in coqc.
I imagined that I could use a -pack option to organize name space,
and possibly for (lightweight) visibility control
by deliberately choosing which files to pack.
For instance, I may pack A.vo and B.vo into AB.vo, and A.vo and C.vo into
AC.vo
where A.vo, B.vo and C.vo are in the same directory;
well-designed packing could help to understand the program structure.
But I might be naively thinking....
> > I ended up in giving distinct names to distinct files;
> > my life has become easier, but I am not very happy.
> this is also the solution we adopted in http://color.loria.fr/. and to make ;
> the life even easier, every thing is compiled using the option
> -R <directory_where_CoLoR_is> CoLoR
> (instead of using many options like "-I dir" or "-I dir/subdir" etc.)
> after that, people willing to import CoLoR modules just have to use this
> option too, or to use the following command:
> Add Rec LoadPath "<directory_where_CoLoR_is" as CoLoR.
> which can be put in the ~/.coqrc file.
This will improve my life; thank you!
Best regards,
Keiko
