coq-club - Re: [Coq-Club] More dependent pattern matching
chronological Thread
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] More dependent pattern matching
  • Date: Mon, 09 Jun 2008 10:12:14 -0400
Edsko de Vries wrote:
I'm stuck again in trying to write some dependent code. I want to index a
vector:
I'm sure someone else will answer your literal question, but I want to offer some advice that would lead to different (easier to discharge) goals. I've found that vectors are _much_ easier to work with if you define them by recursion rather than with inductive types. I'll quote some code from my Lambda Tamer library (http://ltamer.sourceforge.net/) that does this:
Section repeat.
 Variable T : Type.
 Fixpoint repeat (n : nat) : Type :=
   match n with
     | O => unit
     | S n' => T * repeat n'
   end%type.
 Fixpoint index (n : nat) : Type :=
   match n with
     | O => Empty_set
     | S n' => option (index n')
   end.
 Fixpoint select (n : nat) : repeat n -> index n -> T :=
   match n return (repeat n -> index n -> T) with
     | O => fun _ idx => match idx with end
     | S n' => fun rep idx =>
       match idx with
         | None => fst rep
         | Some idx' => select n' (snd rep) idx'
       end
   end.
End repeat.
You can find examples elsewhere in the library of how to use these functions.
