coq-club - Re: [Coq-Club] More dependent pattern matching
chronological Thread
  • From: Conor McBride <conor AT strictlypositive.org>
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] More dependent pattern matching
  • Date: Mon, 9 Jun 2008 15:44:15 +0100
On 9 Jun 2008, at 15:25, Conor McBride wrote:
Hi Adam
On 9 Jun 2008, at 15:12, Adam Chlipala wrote:
Edsko de Vries wrote:
I'm stuck again in trying to write some dependent code. I want to index a
vector:
I'm sure someone else will answer your literal question, but I want to offer some advice that would lead to different (easier to discharge) goals. I've found that vectors are _much_ easier to work with if you define them by recursion rather than with inductive types.
Let's be clear: this is a fact about Coq, not
about vectors.
I should add that things do seem to be getting
better, especially with what Matthieu Sozeau
has been doing. I hope it will cease to be a
fact at all.
Epigram and Agda users seem to have a marginal
preference for the inductive version of vectors,
mostly because (a) it plays better with
implicit syntax and (b) the length information
just gets handled implicitly most of the time.
The recursive construction is a nice workaround,
profiting from the fact that vectors can somehow
take their inductive structure from their
lengths.
Cheers
Conor
