- From: "Andrew McCreight" <continuation AT gmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] automated zeta expansion?
- Date: Sat, 14 Jun 2008 11:09:56 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=T2szHpHjDreWuzt4M9eafFxSNe8Idz1pVwaSRWvPSDFZgGKrulNhSx2RZsQgeAUCj6 KefSCcIvPZLxdgY390wHtW3jmfGUaQVOT3hmBT+bloqOIRJtV/7QPgVzXpg+bOK8n8m1 IblhXAuiCI6TykWr5/QzlnUvQD6BPQ1eGypng=
Hi,
I have many hypothesis of the form
X := A
At some point in my proof new instances of A will occur. Currently, what I do is "replace A with X in * |- *", which works, but is annoying when I have 5 or 6 definitions. A silly percentage of some of my proofs are taken up by this.
What I would like to do is to have a tactic that will automatically do this for all definitions, but the obvious match goal to do this fails with a syntax error:
Ltac unzeta :=
match goal with
| X := ?Y : _ => replace Y with X in *
end.
Toplevel input, characters 66-68
Syntax error: ':' expected after [Prim.name] (in [match_hyps])
Is there some other way to do this?
More generally, is using definitions like this a bad idea? Should I use equality instead? I like having a syntactic distinction between a definition of a variable introduced purely to improve readability and more profound statements of equality, but maybe it isn't worth it if such definitions have a second-class status in the tactic language.
Thanks,
Andrew
- [Coq-Club] automated zeta expansion?, Andrew McCreight
- [Coq-Club] Re: automated zeta expansion?,
Andrew McCreight
- Re: [Coq-Club] Re: automated zeta expansion?, Jean.Duprat
Andrew McCreight
