- To: Andrew McCreight <continuation AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: automated zeta expansion?
- Date: Mon, 16 Jun 2008 14:09:57 +0200
Hi,
After testing it, it sems that using "context" evitates to rewrite
"X:=A" in "X:=X".
I suggest you to try something like :
repeat (progress (match goal with | H : context [A] |- _ => fold X
in H | _ => fold X in |-* end)).
Regards
Jean Duprat
Andrew McCreight wrote:
I
think I have an answer to my own question now. Russell O'Connor
suggested that I could use fold to do what I wanted to do. The
following tactic does what I want, folding up all occurrences of all
definitions in the hypothesis of the proof state:
Ltac zlong :=
repeat (match goal with
| X : _, Y : _ |- _ => progress (fold X in Y)
end);
| X : _ |- _ => progress (fold X)
end).
A more direct way to write this would be:
Ltac zlong :=
| X : _ |- _ => progress (fold X in *)
end).
...but unfortunately "fold X in *" turns "X := A : B" into "X := X :
B", which is obviously something you don't want to do. In fact, doing
"unfold X in X" after that causes Coq to go into an infinite loop.
This behavior has been reported as bug 1389.
http://logical.futurs.inria.fr/coq-bugs/show_bug.cgi?id=1389
So instead a more lengthy version (and possibly slower?) is needed to
prevent folding X in X.
-Andrew
On Sat, Jun 14, 2008 at 11:09 AM, Andrew
McCreight < continuation AT gmail.com>
wrote:
Hi,
I have many hypothesis of the form
X := A
At some point in my proof new instances of A will occur. Currently,
what I do is "replace A with X in * |- *", which works, but is annoying
when I have 5 or 6 definitions. A silly percentage of some of my
proofs are taken up by this.
What I would like to do is to have a tactic that will automatically do
this for all definitions, but the obvious match goal to do this fails
with a syntax error:
Ltac unzeta :=
match goal with
| X := ?Y : _ => replace Y with X in *
end.
Toplevel input, characters 66-68
Syntax error: ':' expected after [Prim.name] (in [match_hyps])
Is there some other way to do this?
More generally, is using definitions like this a bad idea? Should I
use equality instead? I like having a syntactic distinction between a
definition of a variable introduced purely to improve readability and
more profound statements of equality, but maybe it isn't worth it if
such definitions have a second-class status in the tactic language.
Thanks,
Andrew
