coq-club - [Coq-Club] Re: automated zeta expansion?
chronological Thread
  • From: "Andrew McCreight" <continuation AT gmail.com>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: automated zeta expansion?
  • Date: Sat, 14 Jun 2008 21:02:12 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=hNTQvZ+bOMqNzS4jfgaKP9+C1a7hDEZQMqYFjvITjU8XpG4ckDXiTja+/SC3GsaJwL pveatqZ5EJV601lwKWGqG3UIXokAVmw17qSRh97PNs4GO018S39fawUye1tcxhkUBThW LkLOzOg/odtTXCyYq7gwl3nsR8Kak8hA3Ys7I=
I think I have an answer to my own question now.   Russell O'Connor suggested that I could use fold to do what I wanted to do.  The following tactic does what I want, folding up all occurrences of all definitions in the hypothesis of the proof state:
  Ltac zlong :=
    repeat (match goal with
              | X : _, Y : _ |- _ => progress (fold X in Y)
            end);
              | X : _ |- _ => progress (fold X)
            end).
A more direct way to write this would be:
  Ltac zlong :=
              | X : _ |- _ => progress (fold X in *)
            end).
...but unfortunately "fold X in *" turns "X := A : B" into "X := X : B", which is obviously something you don't want to do.  In fact, doing "unfold X in X" after that causes Coq to go into an infinite loop.  This behavior has been reported as bug 1389.
http://logical.futurs.inria.fr/coq-bugs/show_bug.cgi?id=1389
So instead a more lengthy version (and possibly slower?) is needed to prevent folding X in X.
-Andrew
On Sat, Jun 14, 2008 at 11:09 AM, Andrew McCreight <continuation AT gmail.com> wrote:
Hi,
I have many hypothesis of the form
  X := A
At some point in my proof new instances of A will occur.  Currently, what I do is "replace A with X in * |- *", which works, but is annoying when I have 5 or 6 definitions.  A silly percentage of some of my proofs are taken up by this.
What I would like to do is to have a tactic that will automatically do this for all definitions, but the obvious match goal to do this fails with a syntax error:
  Ltac unzeta :=
    match goal with
      | X := ?Y : _ => replace Y with X in *
    end.
Toplevel input, characters 66-68
Syntax error: ':' expected after [Prim.name] (in [match_hyps])
Is there some other way to do this?
More generally, is using definitions like this a bad idea?  Should I use equality instead?  I like having a syntactic distinction between a definition of a variable introduced purely to improve readability and more profound statements of equality, but maybe it isn't worth it if such definitions have a second-class status in the tactic language.
Thanks,
Andrew
