- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Universe constraints
- Date: Sat, 21 Jun 2008 12:20:01 +0100
Hi Adam,
Thanks for your answer. However, based on what my newfound Print command tells
me I'm not sure you're right. The output of
Inductive prod (A B : Type) : Type :=
| pair : A -> B -> prod A B.
Set Printing Universes.
Print prod.
in coq (with -nois) is
Inductive prod (A : Type (* Top.1 *)) (B : Type (* Top.1 *))
: Type (* Top.1 *) := pair : A -> B -> prod A B
In other words, all the types have the *same* universe variable.
However, when I define prod slightly differently,
Inductive prod (A : Type) (B : Type) : Type :=
we get
Inductive prod (A : Type (* Top.1 *)) (B : Type (* Top.2 *))
: Type (* max(Top.1, Top.2) *) := pair : A -> B -> prod A B
Which is approximately what you said. Slightly different again:
Inductive prod : Type -> Type -> Type :=
| pair : forall (A : Type) (B : Type), prod A B.
Print prod.
Print Universes.
We get
Inductive prod
: Type (* Top.1 *) ->
Type (* Top.2 *) -> Type (* max((Top.4)+1, (Top.5)+1) *) :=
pair : forall (A : Type (* Top.4 *)) (B : Type (* Top.5 *)), prod A B
Top.5 <= Top.2
Top.4 <= Top.1
Which is more permissive again.
Interestingly, for the definition of prod from the standard library, Print
gives
Inductive prod
(A : Type (* Coq.Init.Datatypes.22 *))
(B : Type (* Coq.Init.Datatypes.22 *))
: Type (* Coq.Init.Datatypes.22 *) := pair : A -> B -> A * B
which corresponds to our first definition (the most restrictive version).
I'm not sure why the definition in the standard library is defined the way it
is; it seems more restrictive than it needs to be. But I'm sure somebody can
tell me that there is a very good reason for it :)
Thanks again,
Edsko
- [Coq-Club] Universe constraints, Edsko de Vries
- Re: [Coq-Club] Universe constraints,
Adam Chlipala
- Re: [Coq-Club] Universe constraints, Edsko de Vries
Adam Chlipala
Edsko de Vries
- Re: [Coq-Club] Universe constraints, Adam Chlipala
- Re: [Coq-Club] Universe constraints, Hugo Herbelin
Edsko de Vries
Adam Chlipala
Adam Chlipala
