- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Universe constraints
- Date: Sat, 21 Jun 2008 10:00:43 -0400
Edsko de Vries wrote:
[different universes for:]
Inductive prod (A B : Type) : Type :=
| pair : A -> B -> prod A B.
[vs.]
Inductive prod (A : Type) (B : Type) : Type :=
Wow, that is really weird. I had been assuming that these two definitions would desugar to the same internal AST. At least one of them had the behavior I expected. ;-)
The two ways of building universe constraints at least seem provably equivalent from the user's point of view.
Slightly different again:
Inductive prod : Type -> Type -> Type :=
| pair : forall (A : Type) (B : Type), prod A B.
Set Printing Universes.
Print prod.
Print Universes.
We get
Inductive prod
: Type (* Top.1 *) ->
Type (* Top.2 *) -> Type (* max((Top.4)+1, (Top.5)+1) *) :=
pair : forall (A : Type (* Top.4 *)) (B : Type (* Top.5 *)), prod A B
Top.5 <= Top.2
Top.4 <= Top.1
Which is more permissive again.
Your new definition doesn't match up with the old ones, since your pairs contain no data. ;-) But I think adding the data wouldn't have an interesting effect on the universe constraints.
I wouldn't call the last definition "more permissive," because certain uses of it fail to type-check, where uses of both previous versions _would_ type-check. The problem is that you are forced to "go up a universe" relative to the universes of the constructor's arguments, which is a general reason that you'd want to use parameters instead where possible.
To see the problem, try [Check (pair 0 (pair 0 0))] (assuming [Set Implicit Arguments] is on) with all of the definitions (where your last definition is fixed). The first two check out, but the last one has a universe inconsistency.
- [Coq-Club] Universe constraints, Edsko de Vries
- Re: [Coq-Club] Universe constraints,
Adam Chlipala
Edsko de Vries
- Re: [Coq-Club] Universe constraints, Adam Chlipala
Edsko de Vries
- Re: [Coq-Club] Universe constraints, Hugo Herbelin
Edsko de Vries
Edsko de Vries
Adam Chlipala
