- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Universe constraints
- Date: Sat, 21 Jun 2008 17:25:33 +0100
Hi,
> I wouldn't call the last definition "more permissive," because certain
> uses of it fail to type-check, where uses of both previous versions
> _would_ type-check. The problem is that you are forced to "go up a
> universe" relative to the universes of the constructor's arguments,
> which is a general reason that you'd want to use parameters instead
> where possible.
> To see the problem, try [Check (pair 0 (pair 0 0))] (assuming [Set
> Implicit Arguments] is on) with all of the definitions (where your last
> definition is fixed). The first two check out, but the last one has a
> universe inconsistency.
Aah, thanks for pointing that out. Should have noticed that.
Interesting. Why do the two definitions cause different universe
constraints? I understand that Type is not impredicative and so when we
say
Inductive prod : Type -> Type -> Type :=
| pair : forall A : Type, ..
the type of A must be a "lower" Type than the Type in the result of
prod. However, it seems to me that the alternative definition (with A a
parameter to the datatype) introduces the same impredicativity "through
the backdoor".
I presume that one definition introduces a paradox somewhere but the
other doesn't; is there an easy example? Or a reference I should read?
Edsko
- [Coq-Club] Universe constraints, Edsko de Vries
- Re: [Coq-Club] Universe constraints,
Adam Chlipala
Edsko de Vries
Adam Chlipala
- Re: [Coq-Club] Universe constraints, Edsko de Vries
- Re: [Coq-Club] Universe constraints, Adam Chlipala
- Re: [Coq-Club] Universe constraints, Hugo Herbelin
Adam Chlipala
Edsko de Vries
Adam Chlipala
