- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Coq doesn't match identic types?
- Date: Tue, 29 Jul 2008 02:08:06 +0300
Consider theorem 'prop_eq':
> Definition prop_eq := fun p q (eq1:p=q)
=> (match eq1 in _=qdep return p->qdep
with refl_equal => fun p=>p
end) : p->q.
Then:
> Variable (x1 x2 y1 y2:nat) (eq1:x1=y1) (eq2:x2=y2) (lt1:x1<x2).
> Check prop_eq (x1 < x2) (y1 < y2) (f_equal2 lt eq1 eq2) lt1.
gives an error message:
Error: The term "f_equal2 lt eq1 eq2" has type "(x1 < x2) = (y1 < y2)"
while it is expected to have type "(x1 < x2) = (y1 < y2)"
The terms actually are identic. Am I missing something? I'm
using CoqIde, coqtop version 8.1pl1 (Jul. 2007), Linux.
Best regards,
Roman Beslik.
- [Coq-Club] Coq doesn't match identic types?, see tolearn
- Re: [Coq-Club] Coq doesn't match identic types?,
Andrew McCreight
Brian Aydemir
Sean Wilson
- Re: [Coq-Club] Coq doesn't match identic types?, Samuel Bronson
Sean Wilson
Brian Aydemir
- Re: [Coq-Club] Coq doesn't match identic types?, Adam Chlipala
- <Possible follow-ups>
rabforum
Andrew McCreight
