- To: see tolearn <seetolearn AT mail.ru>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Coq doesn't match identic types?
- Date: Wed, 30 Jul 2008 19:42:58 -0400
see tolearn wrote:
Consider theorem 'prop_eq':
Definition prop_eq := fun p q (eq1:p=q)=> (match eq1 in _=qdep return p->qdep
with refl_equal => fun p=>p
end) : p->q.
Then:
Variable (x1 x2 y1 y2:nat) (eq1:x1=y1) (eq2:x2=y2) (lt1:x1<x2).gives an error message:
Check prop_eq (x1 < x2) (y1 < y2) (f_equal2 lt eq1 eq2) lt1.
Error: The term "f_equal2 lt eq1 eq2" has type "(x1 < x2) = (y1 < y2)"
while it is expected to have type "(x1 < x2) = (y1 < y2)"
The terms actually are identic. Am I missing something? I'm
using CoqIde, coqtop version 8.1pl1 (Jul. 2007), Linux.
The usual thing to do when you get a message like that is:
Set Printing All.
Now, running the [Check] command again, you get this more explicit message:
Error: The term "@f_equal2 nat nat Prop lt x1 y1 x2 y2 eq1 eq2" has type
"@eq Prop (lt x1 x2) (lt y1 y2)" while it is expected to have type
"@eq Type (lt x1 x2) (lt y1 y2)"
The essence of the problem is that Coq type inference isn't guaranteed to give "principal types." The types of the first two arguments to [prop_eq] were inferred as [Type] where you want [Prop]. This alternate definition fixes the problem:
Definition prop_eq := fun (p q : Prop) (eq1:p=q)
end) : p->q.
- [Coq-Club] Coq doesn't match identic types?, see tolearn
- Re: [Coq-Club] Coq doesn't match identic types?,
Andrew McCreight
Brian Aydemir
Sean Wilson
- Re: [Coq-Club] Coq doesn't match identic types?, Samuel Bronson
Sean Wilson
Brian Aydemir
- Re: [Coq-Club] Coq doesn't match identic types?, Adam Chlipala
- <Possible follow-ups>
rabforum
Andrew McCreight
