- From: "Andrew McCreight" <continuation AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Coq doesn't match identic types?
- Date: Wed, 30 Jul 2008 16:34:59 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:subject:cc:in-reply-to:mime-version :content-type:references; b=Ji8o4AMvIk/s4ZTfApSx2MUIHLzKkzOBufGM2URHWEDnkLkBO+37uiP9jwyrTLAbQH LFdLvLOGn91EJnNAE4cGLEKeR9qPgsQ0jwNMVpWUwY9liUwHcuASBYO4IrwFLSLhf1ut jwkk8Hq1XcGg3QaWq8PVszD5eHU7xzeMkgkMM=
Doing "Set Printing All" reveals what the problem is:
Toplevel input, characters 54-73:
Error: The term "@f_equal2 nat nat Prop lt x1 y1 x2 y2 eq1 eq2" has type
"@eq Prop (lt x1 x2) (lt y1 y2)" while it is expected to have type
"@eq Type (lt x1 x2) (lt y1 y2)".
-Andrew
-Andrew
On Mon, Jul 28, 2008 at 4:08 PM, see tolearn <seetolearn AT mail.ru> wrote:
Consider theorem 'prop_eq':
> Definition prop_eq := fun p q (eq1:p=q)
=> (match eq1 in _=qdep return p->qdep
with refl_equal => fun p=>p
end) : p->q.
Then:
> Variable (x1 x2 y1 y2:nat) (eq1:x1=y1) (eq2:x2=y2) (lt1:x1<x2).
> Check prop_eq (x1 < x2) (y1 < y2) (f_equal2 lt eq1 eq2) lt1.
gives an error message:
Error: The term "f_equal2 lt eq1 eq2" has type "(x1 < x2) = (y1 < y2)"
while it is expected to have type "(x1 < x2) = (y1 < y2)"
The terms actually are identic. Am I missing something? I'm
using CoqIde, coqtop version 8.1pl1 (Jul. 2007), Linux.
Best regards,
Roman Beslik.
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Coq doesn't match identic types?, see tolearn
- Re: [Coq-Club] Coq doesn't match identic types?, Andrew McCreight
Brian Aydemir
Sean Wilson
- Re: [Coq-Club] Coq doesn't match identic types?, Samuel Bronson
Sean Wilson
Brian Aydemir
- Re: [Coq-Club] Coq doesn't match identic types?, Adam Chlipala
- <Possible follow-ups>
rabforum
