coq-club - [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
chronological Thread
  • To: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
  • Date: Wed, 3 Sep 2008 11:07:44 -0400
Hi,
I have a question about solving obligations generated by Program Fixpoint in the current svn snapshot of Coq 8.2 (r11354). I'm using the documentation at http://coq.inria.fr/V8.2beta4/doc/refman/html/ . Consider the following silly and trivial example. (There's no reason to do this in practice, but it does illustrate my problem.) My questions come at the end.
Require Import Program.
Require Import Omega.
Inductive exp : Set :=
  | bvar : nat  -> exp
  | fvar : nat -> exp
  | abs  : exp -> exp
  | app  : exp -> exp -> exp.
Fixpoint size (e : exp) {struct e} : nat :=
  match e with
    | bvar i => 1
    | fvar x => 1
    | abs e1 => 1 + size e1
    | app e1 e2 => 1 + size e1 + size e2
  end.
(* Obligations Tactic := simpl; omega. (* doesn't parse? *) *)
Program Fixpoint exp_rect'
  (P : exp -> Type)
  (Hbvar : forall n, P (bvar n))
  (Hfvar : forall x, P (fvar x))
  (Habs : forall e1, P e1 -> P (abs e1))
  (Happ : forall e1, P e1 -> forall e2, P e2 -> P (app e1 e2))
  (e : exp) {measure size e} : P e :=
  match e with
    | bvar i => Hbvar i
    | fvar x => Hfvar x
    | abs e1 => Habs e1 (exp_rect' e1)
    | app e1 e2 => Happ e1 (exp_rect' e1) e2 (exp_rect' e2)
  end.
Solve All Obligations using simpl; omega. (* does nothing? *)
Next Obligation. simpl; omega. Qed.
First, is "Obligations Tactic" supposed to parse? How else might I set the default tactic to be applied to generated obligations?
Second, why does Solve All Obligations not do anything? The tactic I've provided it works when I step through the obligations by hand.
At a higher level, I want some way of telling Coq how to solve all generated obligations. The documentation suggests that this is implemented and code in the standard library seems to use this feature, so I'm confused by my own experience here.
Thanks for any help,
Brian
