coq-club - Re: [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
chronological Thread
  • To: Brian Aydemir <baydemir AT cis.upenn.edu>
  • Cc: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
  • Date: Wed, 03 Sep 2008 11:19:49 -0400
Brian Aydemir wrote:
I have a question about solving obligations generated by Program Fixpoint in the current svn snapshot of Coq 8.2 (r11354). I'm using the documentation at http://coq.inria.fr/V8.2beta4/doc/refman/html/ . Consider the following silly and trivial example. (There's no reason to do this in practice, but it does illustrate my problem.)
It's hard to tell which features of [Program] you are using, since your example is implementable trivially with normal [Fixpoint]. For my own edification, can you explain why you are using [Program] instead of [refine]? Your problem is a non-issue with [refine], since you simply run [refine implementation; your_default_tactic] in the proof script for the function you're writing.
