coq-club - Re: [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
chronological Thread
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Program Fixpoint and solving obligations (Coq 8.2 beta/svn)
  • Date: Wed, 3 Sep 2008 17:24:44 +0200
First, is "Obligations Tactic" supposed to parse? How else might I set the default tactic to be applied to generated obligations?
Second, why does Solve All Obligations not do anything? The tactic I've provided it works when I step through the obligations by hand.
At a higher level, I want some way of telling Coq how to solve all generated obligations. The documentation suggests that this is implemented and code in the standard library seems to use this feature, so I'm confused by my own experience here.
Hi,
This is mainly a result of unsynchronized documentation and implementation. In
the trunk (including the doc), "Obligations Tactic" was renamed to "Obligation Tactic"
as I was advised of the better spelling. Then, you have to know that Solve Obligations
uses solely the tactic you give to solve the goal, and does not apply the default tactic
"program_simpl" before calling it, which can considerably simplify the goal and
always does [intros]. So, the following works:
<< Obligation Tactic := program_simpl ; simpl ; omega. >>
Cheers,
-- Matthieu
