coq-club - Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad
chronological Thread
  • To: Vladimir Komendantsky <komendantsky AT gmail.com>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>, "Agda mailing list" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] Re: [Agda] Termination proof in partiality monad
  • Date: Wed, 19 Nov 2008 10:56:12 +0000
Hi all,
I was experimenting with Vladimir's suggestion (based on Capretta's equivalence relation), when a collegue (Wendy Verbruggen) realized that the fixed point definition I had been using is wrong (Dan, I think this is the definition you're using too, right?)
CoFixpoint lfpAux (A B:Set)
    (k:A -> Delay B)
    (f:(A -> Delay B) -> (A -> Delay B))
    (a:A) : Delay B :=
  match f k a with
  | Now a => Now a
  | Later d' => Later (lfpAux (f k) f a)
  end.
Definition lfp (A B:Set)
    (a:A) : Delay B :=
  lfpAux (fun x => bottom) f a.
At least, we *think* this is wrong: it is missing some notion of searching for the least fixed point (called 'omegarace' in http://www.informatik.uni-bonn.de/~ralf/WG2.8/22/slides/tarmo.pdf or 'parallel_search' in Caprettas paper). As a result, in some of our experiments computations were diverging that shouldn't be. Unfortunately, correcting this makes the unfolding of factorial much more complicated still and and we're now even further removed from proving anything about fac :/
Edsko
