coq-club - [Coq-Club] Re: Agda beats Coq
chronological Thread
  • From: Nils Anders Danielsson <nad AT Cs.Nott.AC.UK>
  • To: Agda mailing list <agda AT lists.chalmers.se>, coq-club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Re: Agda beats Coq
  • Date: Fri, 21 Nov 2008 10:01:56 +0000
On 2008-11-20 23:21, Dan Doel wrote:
[...] all the unfolding that needs to happen to make types check
automatically happens because of the observations we need to make.
This is the key point. I have another example, which I think illustrates
this well.
First an unsuccessful codata approach:
  -- Possibly infinite trees.
  codata Tree (A : Set) : Set where
    leaf : Tree A
    node : (l : Tree A) (x : A) (r : Tree A) -> Tree A
  map : forall {A B} -> (A -> B) -> Tree A -> Tree B
  map f leaf         ~ leaf
  map f (node l x r) ~ node (map f l) (f x) (map f r)
  -- Tree equality.
  codata _≈_ {A : Set} : (t₁ t₂ : Tree A) -> Set where
    leaf : leaf ≈ leaf
    node : forall {l₁ l₂ x₁ x₂ r₁ r₂}
           (l≈ : l₁ ≈ l₂) (x≡ : x₁ ≡ x₂) (r≈ : r₁ ≈ r₂) ->
           node l₁ x₁ r₁ ≈ node l₂ x₂ r₂
  map-cong : forall {A B} (f : A -> B) {t₁ t₂ : Tree A} ->
             t₁ ≈ t₂ -> map f t₁ ≈ map f t₂
  map-cong f leaf            ~ ?
  map-cong f (node l≈ x≡ r≈) ~ ?
How do you prove that map preserves equality? The type of the last goal
is
  map f (node .l₁ .x₁ .r₁) ≈ map f (node .l₂ .x₂ .r₂),
and the node constructor of _≈_ does not match this type. One can
perhaps get around this in some way, but the proof will likely be
inelegant.
Let's try to emulate Anton's approach instead (without his syntactic
sugar, since it has not been implemented):
  mutual
    data TreeD (A : Set) : Set where
      leaf : TreeD A
      node : (l : Tree A) (x : A) (r : Tree A) -> TreeD A
      tree : (d : TreeD A) -> Tree A
  destruct : forall {A} -> Tree A -> TreeD A
  destruct (tree d) = d
  map f t with destruct t
  map f t | leaf       ~ tree leaf
  map f t | node l x r ~ tree (node (map f l) (f x) (map f r))
  mutual
    data _≈D_ {A : Set} : (t₁ t₂ : TreeD A) -> Set where
      leaf : leaf ≈D leaf
             node l₁ x₁ r₁ ≈D node l₂ x₂ r₂
    -- Note that the type is not indexed on codata, only parameterised.
    codata _≈_ {A : Set} (t₁ t₂ : Tree A) : Set where
      tree : (d≈ : destruct t₁ ≈D destruct t₂) -> t₁ ≈ t₂
  destruct≈ : forall {A} {t₁ t₂ : Tree A} ->
              t₁ ≈ t₂ -> destruct t₁ ≈D destruct t₂
  destruct≈ (tree eq) = eq
  map-cong f t₁≈t₂ with destruct≈ t₁≈t₂
  map-cong f {tree ._} {tree ._} t₁≈t₂ | leaf          ~ ?
  map-cong f {tree ._} {tree ._} t₁≈t₂ | node l≈ x≡ r≈ ~ ?
Now the last goal has type
  map f (tree (node .l₁ .x₁ .r₁)) ≈ map f (tree (node .l₂ .x₂ .r₂)).
Note that we can use the tree constructor of _≈_ here, because its type
matches anything. In
  map-cong f {tree ._} {tree ._} t₁≈t₂ | node l≈ x≡ r≈ ~ tree ?
the goal has type
  destruct (map f (tree (node .l₁ .x₁ .r₁))) ≈D
  destruct (map f (tree (node .l₂ .x₂ .r₂)))
which, due to the presence of destruct, evaluates to
  node (map f .l₁) (f .x₁) (map f .r₁) ≈D
  node (map f .l₂) (f .x₂) (map f .r₂),
which can easily be proved. Note that there is no need to use explicit
unfoldings; the use of destruct in the type of tree ensures that things
evaluate exactly when we want them to (in this example, at least).
(Note that the pattern matching on {tree ._} is not part of Anton's
approach, but I think it is harmless. In fact, both map and map-cong
could just as well be written without destruct(≈):
  map f (tree leaf)         ~ tree leaf
  map f (tree (node l x r)) ~ tree (node (map f l) (f x) (map f r))
  map-cong f {tree ._} {tree ._} (tree leaf)            ~ tree leaf
  map-cong f {tree ._} {tree ._} (tree (node l≈ x≡ r≈)) ~
    tree (node (map-cong f l≈) (≡-cong f x≡) (map-cong f r≈))
However, destruct needs to be used in _≈_.)
/NAD
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
