- To: Brian Aydemir <baydemir AT cis.upenn.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Definitions inside type class definitions (Coq 8.2beta)
- Date: Mon, 24 Nov 2008 23:10:42 +0100
Le 24 nov. 08 à 22:46, Brian Aydemir a écrit :
Hi,
Hi,
I have another question about type classes in Coq 8.2beta. (-:
When defining a record type, I can use "field_name := foo" in order to
explicitly define a field. Since the type class mechanism is built upon
records (or so it seems), can I do the same when defining a type class?
Not yet, in 8.2 you don't even get to parse that.
It is parsed now (in current trunk), as we completely unified parsing of
record/class/(co-)inductive declarations but not supported in
instance declarations (thanks for the accidental bug report :). Of course
the question is, do you get the right to redefine it afterwards à la Haskell.
Currently it works like for records, creating a let-in in the constructor, with
no redefinition allowed.
Cheers,
-- Matthieu
- [Coq-Club] Definitions inside type class definitions (Coq 8.2beta), Brian Aydemir
- Re: [Coq-Club] Definitions inside type class definitions (Coq 8.2beta), Matthieu Sozeau
- [Coq-Club] Coq & Java applet, Thery Laurent
