coq-club - Re: [Coq-Club] List OrderedType as OrderedType?
chronological Thread
  • To: "Pierre Letouzey" <Pierre.Letouzey AT pps.jussieu.fr>
  • Cc: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] List OrderedType as OrderedType?
  • Date: Wed, 26 Nov 2008 18:45:48 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version :content-type:references:x-google-sender-auth; b=uwt03qK09fA8614r4Ao+Tg2W7EErfOPPTvLitUGxMf+NH+XkXCH6bUAPQA4TVp4ykv O6IxGKMq7muCi10owgmyleQJMhmt34VTrCSl9EXJog/PWovdP9lZK7yQSlj9TAZsQiMa rb3vGApNHz65T5UDgAc9qptJnS5ZioGRj2ILc=
On Wed, Nov 26, 2008 at 5:38 PM, Pierre Letouzey
 wrote:
> On Tue, Nov 25, 2008 at 02:56:21PM -0500, M. Scott Doerrie wrote:
>> I've been searching the Coq standard library and have been unable to
>> find a functor that creates an OrderedType given an FSet or even a List
>> of OrderedTypes.  This seems relatively straightforward given the
>> implementation of PairOrderedType, so I've probably missed it.  I'd
>> rather not duplicate effort, so I thought I'd ask first.
>> Scott Doerrie
> Concerning lists of OrderedType.t, FSetList.Make is building a
> FSetInterface.S whose base type is a sorted list attached with its
> sortedness proof. As before, this FSetInterface.S can be seen as an
> OrderedType. If you want to deal with arbitrary lists and not only the
> sorted ones, nothing exists yet in the standard library, but it should
> not be too difficult to build something (indeed, PairOrderedType can
> be a good source of inspiration). If you write this kind of functor,
> let me know, it might be interesting to include it in the standard
> library.
I had actually written such a functor (see attached file) some time
ago, it builds an ordered type for lists with pointwise equality and
lexicographic order. [eq] and [lt] are defined as inductives rather
than functions because I find inversion really convenient.
Hope this helps,
Stéphane L.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
Attachment: ListOrderedType.v
Description: Binary data
